MakerBot METHOD X Tutorial - Maximize Build Volume
In this video I share how to manage the settings so you can maximize your print volume. Since MethodX is dual extruder machine, if you are using both extruders you lose about 1.0 (25.4 mm) of build volume in the X-direction. However, if you are building with no support material, you can get that area back, but you need to choose you settings correctly.
