Part 21 : Crankshaft Pin
A crankshaft pin or a crankpin is the part of the crank of a crankshaft to which the connecting rod is attached. Crankpins transfer up-and-down motion between the crankshaft and connecting rod. The big end of the connecting rod is connected to the crankpin of the crankshaft by way of a bearing. Blueprint parts retrieved from http://www.inventorwizard.nl/blueprints/index.html summarized in folder https://drive.google.com/drive/folders/1G_wAXvDLRlHb-FcoeNGU3P11jWXxuHjO?usp=sharing.
  1. Step 1: 21. Crankshaft Pin - 6 Cylinder Radial Engine Inventor Tutorial
