Piston Design in UNIGRAPHICS
A piston can convert a pressure from a gas or a fluid to produce a force or, conversely, uses a force to create a pressure in a gas or fluid. Normally, the piston is sealed in a cylinder by a close fit or an fixed or expanding sliding seal.
Step 1: Follow the video
