Project curve
In this tutorial, you will learn how to do lofted boss using project curves. The project curve is located at the square corner. This project curve is very important for our 3D model to be as we want it to be.
The lesson you will learn from the tutorial is
1. create a new plane using sketch lines
2. project curve
3. lofted boss
You will also find out what the difference is without using the project curve and with the project curve in this tutorial.
