Radial Engine / Articulated Rod in unigraphics
Design of Radial engine's articulated rod using Unigraphics.
A connecting rod is an engine component that transfers motion from the piston to the crankshaft and functions as a lever arm. Connecting rods are commonly made from cast aluminum alloy and are designed to withstand dynamic stresses from combustion and piston movement.
