SOLIDWORKS advanced tutorials | Replacing faces
Learn how to replace faces in SOLIDWORKS?
Replacing a Single Set of Faces
1. Make sure that your replacement surface body is wider and longer than the faces you are replacing.
2. Click Replace Face on the Surfaces toolbar, or click Insert - Face -Replace.
3. In the Property Manager, under Replace Parameters: Select the faces to replace for Target faces .
4. Click OK .
