SOLIDWORKS DRAFT USING PARTING LINE
Solidworks draft is features tool which used to create tapered faces on specified angle, using a netural plane or parting line. The draft tool is located in both features CommandManager and Insert Menubar. You can apply this feature tool directly on designed model to get tapered surface with desired angle.
Step 1: SOLIDWORKS DRAFT USING PARTING LINE
