SolidWorks Flexible Sub-assembly (Easy way)
Small
Most of us find it boring to keep repeating the same mates between the same parts within large assemblies, so we make "Sub-assembly" files to work with. But unfortunately, the default configuration for ALL sub-assemblies makes them "rigid"; as if they were a single part.
Here we'll know how to make them "flexible", and in the easiest way possible.
  1. Step 1: Right click
    Just right click on the desired sub-assembly.
  2. Step 2: Component Properties
    Now choose component properties.
  3. Step 3: Flex your Sub-assembly
    In the dialog box, under Solve as, select Flexible, then click OK.
  4. Step 4: Easy way (just one step)
    Right click on the desired sub-assembly, then select "Make Subassembly Flexible".
    Easy, isn't it?
  5. Step 5: Not a real step
    But how can we differentiate between rigid and flexible sub-assemblies?
    Are we supposed to open each one's component properties, or right click on each of them?
    The answer is simple, rigid sub-assemblies have this icon before them (in the FeatureManager Design Tree)
    While Flexible sub-assemblies have this icon
    Only one exception to this "answer", sub-assemblies have the flexible icon while they are rigid when first imported. They don't have the rigid icon unless been toggled between the two configurations before. (Yeah, stupid glitch)
Please log in to add comments
