Solidworks Tutorial | Solidworks Shell Command _ Advanced lessons | 3d Modeling Tutorial
The shell tool is mainly used for shelling ie hollows out a part, leaves open the faces you select, and creates thin-walled features on the remaining faces.
If you do not select any face on the model, you can shell a solid part, creating a closed, hollow model. You can also shell a model using multiple thicknesses.
You can create shell features with different thicknesses for different faces. You can remove faces, set a default thickness for the remaining faces, then set different thicknesses for faces you select from the remaining faces
Reference:
https://help.solidworks.com/2019/english/SolidWorks/sldworks/c_Shells_Folder.htm
Learning this tool will greatly help you advance in your Solidworks journey
You can contact me for more specific tutorial and tuition
Whatsapp: +233241289594
Email: dadziepaulaa@yahoo.com
More models can be found here: https://grabcad.com/paul.dadzie-1/models
Facebook: https://web.facebook.
Step 1: Shell tool usage
