Spur Gear Meshing
Spur gear meshing refers to the process by which two spur gears engage with each other to transmit power and motion through their teeth. Spur gears are the most common type of gears, characterized by straight teeth that are parallel to the gear axis and mounted on parallel shafts.
Key Points:
Contact: When two spur gears mesh, the teeth of one gear (the driving gear) push against the teeth of the other gear (the driven gear), transferring torque and rotational motion.
Pitch Point: The point where the teeth of the two gears make contact is called the pitch point. At this point, the linear velocity of both gears is the same, ensuring smooth transmission.
Pressure Angle: The angle between the line of action (force transmission line) and the tangent to the pitch circle is called the pressure angle, typically 20° in modern gears. It determines the shape and strength of the teeth.
Line of Action: The teeth slide and roll against each other along the line of action during meshing, which ensures continuous contact and minimizes vibration.
Backlash: A small amount of clearance between meshing teeth (backlash) is often maintained to prevent jamming and accommodate thermal expansion or misalignment.
Spur gear meshing is ideal for low- to medium-speed applications and provides high efficiency and accurate motion transfer, making it widely used in mechanical systems such as gearboxes, clocks, and industrial machinery.
Step 1: Start an Assembly File
Open SolidWorks and click on File > New > Assembly.
Step 2: Create a Reference Sketch for Gear Placement
Click on the Right Plane, then select Sketch.
Draw a vertical line through the Origin, and then a horizontal line starting from the Origin.
Use the Symmetric relation to make the endpoints of the vertical line symmetric about the horizontal line.
At each end of the vertical line, draw a circle of 3-inch diameter. These circles will represent the pitch circles for positioning the gears.
Step 3: Insert Spur Gears from Toolbox
Open the Design Library tab.
Navigate to Toolbox > ANSI Inch > Power Transmission > Gears > Spur Gears.
Drag and drop a spur gear into the assembly. A configuration window will appear.
Set the required gear properties (e.g., number of teeth, pitch diameter, pressure angle), then click OK.
Insert two identical gears using the same method.
Step 4: Apply Mates to Position the Gears
For each gear, apply a Concentric Mate between the circular face of the gear bore and the circle from the sketch.
Apply a Coincident Mate between the side face of one gear and the side face of the other (or a fixed reference plane) to align their thickness.
Step 5: Align Gear Orientation for Proper Tooth Engagement
Make a Coincident Mate between the Right Plane of the assembly and the Plane1 (or Right Plane) of each gear.
This ensures both gears are oriented properly so that the teeth mesh correctly.
Step 6: Apply Gear Mate for Motion Simulation
- Go to Mate > Mechanical Mates > Gear.
- Select the outer cylindrical faces (or circular edges) of both spur gears.
- Set the gear ratio (e.g., 1:1 for identical gears) and click OK.
