Steady Simulation of Bifurcation and Turgo Turbine Tutorial on Ansys CFX
In this video, you will learn how to simulate bifurcation and a Turgo turbine using Ansys CFX. I will cover geometry setup, boolean operations, naming, meshing, and physics setup. In the results section, I'll demonstrate how to extract contours, visualize streamlines, and use the calculator function to calculate torque.
Step 1: Video Link for Simulation of Bifurcation and Turgo Turbine Tutorial
