Structural analysis of Plier | Solidworks Pin Connection Simulation
Static structural analysis of a plier will be done in Solidowrks simulation using solidowrks pin connection tool.
The set of pliers shown below is used to tighten a bolt. It is desired to calculate the stresses when the process is just starting. The bolt provides a torsional stiffness of 200 lb.in/rad to the pliers. Forces to secure the grip and prevent slipping are applied to the handles. A couple of forces are applied on opposite faces of the handles to rotate the bolt.
From this simulation tutorial, you learn.....
How to define pin connections in Solidworks?
How to define moment creating force?
Evaluate pin shear and axial forces?
