Tutorial on boolean operations in CatiaV5
This is a short tutorial in boolean operation in Catia V5.
Step 1: Make a solid
Make a solid, copy the part body and paste it as result in the part.
Step 2: Modify the body parts
Make the desired modifications on the new body parts that you copied under the part body.
Step 3: Parametrization
You can use parameters and formulas to different values.
