(VIDEO TUTORIAL) Solidworks Tutorial #160 How to Design a Single Clutch Plate Assembly in Solidworks Easy Design
Single plate Clutch is the most common type of clutch used in motor vehicles. It consists of only one clutch plate, mounted on the splines of the clutch shaft. ... The pressure plate is bolted to the flywheel through clutch springs and is free to slide on the clutch shaft when the clutch pedal is operated.
Step 1: Solidworks Tutorial #160 How to Design a Single Clutch Plate Assembly in Solidworks Easy Design
Step 2: Rendering Images
