Wall mounted spool holder
Materials:
- 3/4 PVC pipe
- x2 90° joints for 3/4 PVC pipe
- x2 "T" joints for 3/4 PVC pipe
- x2 3/4 PVC pipe caps
- x2 3/4 PVC wall mount
Optional:
- 3/4 PVC pipe
- x4 90° joints for 3/4 PVC pipe
Step 1: Decide dimensions
First, decide dimensions for the hanging length and spool axle, so you can cut the necessary of the PVC pipe.
Step 2: Make the assembly
Assemble all the parts to create the structure.
I used 3d printed pipe caps for it. You can find them here:
Step 3: Paint the structure (optional)
Give a little color to it.
Step 4: Install with wall mounts
Install to the wall with 3/4 PVC pipe mounts.
I printed on ABS these parts since i couldn't find any option where i live. You can find them here too: 3/4 PVC pipe kit | 3D CAD Model Library | GrabCAD
Step 5: Enjoy
Try printing your parts, make sure the machine can pull the filament and that the spool can rotate continously.
I've been printing with this system and never had any problem with it.
If you install T joints on the top, you can customize with your favorite models by adding them to caps.
