Top down assembly with skeleton model in pro engineer.
By e19 on 28 Jun 01:48 1 answer 2644 views 2 comments
basic idea about how its done.
1 answer
  • e19
    e19 11 months ago
    following general steps to make top down assembly from skeleton model
    1. Step 1
      create component in assembly mode then select skeleton model
      Medium
    2. Step 2
      choose default options and click ok
      Medium
    3. Step 3
      skeleton model appears in assembly model tree right click and open it
      Medium
    4. Step 4
      capture the outline of assembly in skeleton model
      Medium
    5. Step 5
      save and close your skeleton
      Medium
    6. Step 6
      back to assembly again create another part this time select solid in subtype
      Medium
    7. Step 7
      choose default options here.
      Medium
    8. Step 8
      place the component wherever you like,it's not known at this stage as where component will be placed,it can be tweaked later
      Medium
    9. Step 9
      open this newly placed part from model tree
      Medium
    10. Step 10
      to copy geometry from skeleton part navigate insert>shared data>copy geometry
      Medium
    11. Step 11
      i have not published geometry from assembly so have to turn off this option
      Medium
    12. Step 12
      from reference tab browse to skeleton part ,you can use default options here
      Medium
    13. Step 13
      from reference tab browse to skeleton part select geometry whatever you need to make part
      Medium
    14. Step 14
      make part with copied geometry save and close
      Medium
    15. Step 15
      when you save the part,it appears in assembly,same way do it for other geometry.
      Medium
    16. Step 16
      completed assembly
      Medium
Add your answer to: "Top down assembly with skeleton model in pro engineer."
