Top down assembly with skeleton model in pro engineer.
Small
following general steps to make top down assembly from skeleton model
    create component in assembly mode then select skeleton model
    choose default options and click ok
    skeleton model appears in assembly model tree right click and open it
    capture the outline of assembly in skeleton model
  5. Step 5:
    save and close your skeleton
  6. Step 6:
    back to assembly again create another part this time select solid in subtype
  7. Step 7:
    choose default options here.
  8. Step 8:
    place the component wherever you like,it's not known at this stage as where component will be placed,it can be tweaked later
  9. Step 9:
    open this newly placed part from model tree
  10. Step 10:
    to copy geometry from skeleton part navigate insert>shared data>copy geometry
  11. Step 11:
    i have not published geometry from assembly so have to turn off this option
  12. Step 12:
    from reference tab browse to skeleton part ,you can use default options here
  13. Step 13:
    from reference tab browse to skeleton part select geometry whatever you need to make part
  14. Step 14:
    make part with copied geometry save and close
  15. Step 15:
    when you save the part,it appears in assembly,same way do it for other geometry.
  16. Step 16:
    completed assembly
Please log in to add comments
