Tutorial on 2D Simplification Static analysis in SolidWorks of Structural beam.
Tutorial - 2D Simplification Static analysis in SolidWorks
Step 1
Start SolidWorks in Part mode.
Step 2
Tools >> Addins.
Step 3
Check the SolidWorks Simulation and SolidWorks Toolbox.
Step 4
Under Office products click Structural steel.
Step 5
Select Front plane and the beam and click create.
Step 6
Now we have the sketch for that particular beam.
Step 7
Edit the sketch and move it to the center.
Step 8
Under Simulation select New Study in Study Advisor.
Step 9
In name type Bam and keep the default settings. Click OK.
Step 10
Select front plane and input depth = 10000mm. Click OK.
Step 11
Right click the part1 and apply edit material.
Step 12
Select ASTM A36 Steel which is mostly used structural material.
Step 13
Right click fixtures and select fixed geometry.
Step 14
Select lower edge and click OK.
Step 15
Select force under external loads.
Step 16
Select upper edge and input force value 10000N.
Step 17
Under run click create mesh.
Step 18
Change mesh density to fine for better results.
Step 19
Click run under run.
Step 20
After solver is done we will have results.
Step 21
Front view.
Step 22
We can change the plots under results.
Step 23
Right click Displacement and select probe.
Step 24
Select on selected entities and then upper edge.
Step 25
Click Update.
Step 26
Click Plot.
Step 27
Now we have the plot of displacement vs distance.
how i can have plots such as Edge plot in your tutorial in solidworks motion study?
I had used Simulation for Assembly (Double Girder Overhead traveling crane). For contact we just defined the global component set of contacts. At start there were unwanted results. But after changing the geometry the result were as we wanted. :)
In case of dynamic we defined initial condition of velocity (.5m/sec) for crab and the load curve (Sine) for 15sec. :P It took 3 hours and the CWR file was about 5.5GB. :P We have the result for displacement, but when we clicked stress, the solidworks got out of memory and crashed. :P
I dont know how to use the Simulation in a assemble... anyone her can explain it? i dont know how to use for example contact with parts...an other things....
Gill Thank you. Is it possible to analyze a part in the whole range of simulation time the machine action?
've tried all sorts of possibilities. Just do not pass it overcame. Always computer crashes or data provides an engineering impossibility. Shortly have a very expensive course SW adapter on charges they claim works with you attend the course. If I had to update for all of us would love Ladcnbatr. Thanks anyway.
In my experience , static analysis must work for all elements at once to find the weakest place in assembly or parts. This is a good example but is not real.
If a beam is long 20 meters and is supported on bearings, where is the weakest place on the beam? In the middle?
Next criteria is a deformations!
In most cases engineers is push over R_designed above Rp 0.2, but only in the aim a lowering a mass of construction -> lower cost , but in these times the wheather is not a predictable as is 30 years ago, and we have now more nad more a structure collapsing and dead peoples. And who will go in prison- you my dear collegaus, no your boss, no politicians, no economist , just you!
I agree... we must see the global analysis... but is it that i dont kwow how to do in SOLIDWORKS, but in one part i know....
