Tutorial - 2D Simplification Static analysis in SolidWorks
Start SolidWorks in Part mode.
Tools >> Addins.
Check the SolidWorks Simulation and SolidWorks Toolbox.
Under Office products click Structural steel.
Select Front plane and the beam and click create.
Now we have the sketch for that particular beam.
Edit the sketch and move it to the center.
Under Simulation select New Study in Study Advisor.
In name type Bam and keep the default settings. Click OK.
Select front plane and input depth = 10000mm. Click OK.
Step 11:
Right click the part1 and apply edit material.
Step 12:
Select ASTM A36 Steel which is mostly used structural material.
Step 13:
Right click fixtures and select fixed geometry.
Step 14:
Select lower edge and click OK.
Step 15:
Select force under external loads.
Step 16:
Select upper edge and input force value 10000N.
Step 17:
Under run click create mesh.
Step 18:
Change mesh density to fine for better results.
Step 19:
Click run under run.
Step 20:
After solver is done we will have results.
Step 21:
Front view.
Step 22:
We can change the plots under results.
Step 23:
Right click Displacement and select probe.
Step 24:
Select on selected entities and then upper edge.
Step 25:
Click Update.
Step 26:
Click Plot.
Step 27:
Now we have the plot of displacement vs distance.
