Here is the fourth part.
Step 1
Split line and project them on back face.
Step 2
Inner face >> Sketch.
Step 3
Convert the inner edge and extrude cut it by 0.50mm.
Step 4
Dome it by 0.4mm.
Step 5
Circular face >> Sketch.
Step 6
Convert the edge.
Step 7
Extrude it by .10mm and uncheck Merge result.
Step 8
Bottom face >> Sketch.
Step 9
Draw a slot.
Step 10
Mirror it about a center line on origin.
Step 11
Extrude cut by 1mm.
Step 12
Left face >> Sketch.
Step 13
Draw this slot.
Step 14
Split line and then select inner face.
Step 15
Step 16
Draw a rectangle.
Step 17
Extrude cut by 2.5mm.
Step 18
Chamfer the cut edge by 0.15mm at 45º.
Step 19
Step 20
Draw two circles.
Step 21
Split line and select bottom face.
Step 22
Step 23
Draw a 5 side polygon and construct star.
Step 24
Repeat same step for other circular face. Make polygon construction.
Step 25
Extrude cut by 0.50mm.
Step 26
Here is fifth part.
http://grabcad.com/questions/tutorial-making-iphone-4s-in-solidworks-part-5
