Tutorial on Modeling Spark plug in SolidEdge ST4.
By Sudhir Gill on 13 Apr 18:45 3 answers 2207 views 3 comments
Tutorial on Modeling Spark plug in SolidEdge ST4 for Solid Edge Tutorials Challenge.
Added images
Square
  • Sudhir Gill
    Sudhir Gill about 1 year ago
    This tutorial mainly focus on using a image file to model a spark plug. I am no expert in SolidEdge but if you encounter any problem while performing any step let me know. I will help you in all possible ways.
    The required Drawing file is attached with the model (Spark Plug) and also with the Question.
    1. Step 1
      Start SolidEdge in ISO Part mode. The tutorial is made in Synchronous Mode but will work same for ordered.
      Medium
    2. Step 2
      Check the base reference planes to show them.
      Medium
    3. Step 3
      Press CTRL+F for Front view.
      Medium
    4. Step 4
      Click Image Icon.
      Medium
    5. Step 5
      Click Browse.
      Medium
    6. Step 6
      Select the Spark Plug drawing file. Click Open. Then Click OK.
      Medium
    7. Step 7
      Now the image is inserted.
      Medium
    8. Step 8
      Adjust it so that the center line is at origin.
      Medium
    9. Step 9
      Select line tool.
      Medium
    10. Step 10
      With snapped to the X axis start making line.
      Medium
    11. Step 11
      Make the line vertical and click the end point.
      Medium
    12. Step 12
      Choose curve.
      Medium
    13. Step 13
      Select the end point of the line.
      Medium
    14. Step 14
      Make the curve along the drawing.
      Medium
    15. Step 15
      Now make a line.
      Medium
    16. Step 16
      Click Tangent tool under sketching tab.
      Medium
    17. Step 17
      Make the curve tangent to the line.
      Medium
    18. Step 18
      Now again line.
      Medium
    19. Step 19
      Make a horizontal line.
      Medium
    20. Step 20
      Select arc by 3 points tool.
      Medium
    21. Step 21
      Make the arc about the drawing curve.
      Medium
    22. Step 22
      Now make a horizontal line.
      Medium
    23. Step 23
      Select fillet tool.
      Medium
    24. Step 24
      Fillet the arc and the line. This will also add an tangent relation.
      Medium
    25. Step 25
      Now make lines.
      Medium
    26. Step 26
      Arc by three points and line.
      Medium
    27. Step 27
      Make lines.
      Medium
    28. Step 28
      Arc by 3 points.
      Medium
    29. Step 29
      Line and Arc by 3 points.
      Medium
    30. Step 30
      Make similar geometry as in last step.
      Medium
    31. Step 31
      Make line.
      Medium
    32. Step 32
      Make horizontal line.
      Medium
    33. Step 33
      Line and arc.
      Medium
    34. Step 34
      Now make Horizontal line and when in half of Nut click.
      Medium
    35. Step 35
      Make vertical line by snapping it the drawing other side lines.
      Medium
    36. Step 36
      Make lines.
      Medium
    37. Step 37
      Horizontal and vertical lines.
      Medium
    38. Step 38
      Again trace lines.
      Medium
    39. Step 39
      Arc & lines.
      Medium
    40. Step 40
      Make lines.
      Medium
    41. Step 41
      Make arc.
      Medium
    42. Step 42
      Line tool.
      Medium
    43. Step 43
      Trace arc and then line geometry.
      Medium
    44. Step 44
      Fillet the arc and vertical line.
      Medium
    45. Step 45
      Make lines.
      Medium
    46. Step 46
      Make vertical line so as to pass the virtual center axis of the plug.
      Medium
    47. Step 47
      Goto the left side and start making the line.
      Medium
    48. Step 48
      Pass it through the whole image.
      Medium
    49. Step 49
      Trim the lines to obtain closed region.
      Medium
    50. Step 50
      Press CTRL+I for Isometric view.
      Medium
    51. Step 51
      Select the region.
      Medium
    52. Step 52
      Select revolve.
      Medium
    53. Step 53
      Change the setting to 360º.
      Medium
    54. Step 54
      Right click.
      Medium
    55. Step 55
      Select the center line and the revolve is generated.
      Medium
    56. Step 56
      Zoom to the Nut area.
      Medium
    57. Step 57
      Select Polygon by center tool.
      Medium
    58. Step 58
      Select this face. Press F3 to lock it so the sketch is generated on this plane.
      Medium
    59. Step 59
      Keep the mouse on circular edge and the center of the circle appear by cross.
      Medium
    60. Step 60
      Select the center and make the polygon.
      Medium
    61. Step 61
      Select Extrude tool.
      Medium
    62. Step 62
      Select the Polygon region.
      Medium
    63. Step 63
      Front view.
      Medium
    64. Step 64
      Symmetric type.
      Medium
    65. Step 65
      Extrude it by keeping the Nut height in drawing in mind.
      Medium
    66. Step 66
      CTRL+T for Top view.
      Medium
    67. Step 67
      Draw a triangle using line tool.
      Medium
    68. Step 68
      Mirror tool.
      Medium
    69. Step 69
      Select the triangle by using selection polygon.
      Medium
    70. Step 70
      Mirror it about the center line.
      Medium
    71. Step 71
      Isometric view (CTRL+I). Revolve tool.
      Medium
    72. Step 72
      Select both region while holding CTRL key.
      Medium
    73. Step 73
      Change revolve extent to 360º.
      Medium
    74. Step 74
      Change type to remove.
      Medium
    75. Step 75
      Revolve it about the center axis.
      Medium
    76. Step 76
      Now the nut is prepared.
      Medium
    77. Step 77
      Front View.
      Medium
    78. Step 78
      Select Ellipse by center point tool.
      Medium
    79. Step 79
      Make it.
      Medium
    80. Step 80
      Make a horizontal line along center axis.
      Medium
    81. Step 81
      Select Helix tool in Add.
      Medium
    82. Step 82
      Select the line.
      Medium
    83. Step 83
      Select the ellipse region.
      Medium
    84. Step 84
      Right click.
      Medium
    85. Step 85
      Input 12 turns.
      Medium
    86. Step 86
      Front View.
      Medium
    87. Step 87
      Trace the lines.
      Medium
    88. Step 88
      Fillet them.
      Medium
    89. Step 89
      Revolve it by symmetric and about this line by 15º. Right click to accept.
      Medium
    90. Step 90
      Select revolve tool and then select the end face of the thread.
      Medium
    91. Step 91
      Revolve it by 360º along the face end line.
      Medium
    92. Step 92
      Right click to accept it.
      Medium
    93. Step 93
      Fillet the edges.
      Medium
    94. Step 94
      Select circle tool and then select the end face of the body.
      Medium
    95. Step 95
      F3 to lock and then snap to the center point of the edge.
      Medium
    96. Step 96
      Make a circle.
      Medium
    97. Step 97
      Medium
    98. Step 98
      Extrude it by remove inside the body.
      Medium
    99. Step 99
      CTRL+I for Isometric View.
      Medium
    100. Step 100
      Now our Spark plug is ready by tracing an image file.
      Medium
  • jairo luis
    jairo luis about 1 year ago
    too good this material, I used to practice in solidworks as yet do not learn as an image crosquizar
    regards
Add your answer to: "Tutorial on Modeling Spark plug in SolidEdge ST4."
