Tutorial on Modeling Bolt in SolidEdge ST4?
By Sumit Balhara on 23 Apr 06:01 1 answer 2464 views 1 comment
Tutorial on Modeling M20 Bolt in SolidEdge.
1 answer
  • Sumit Balhara
    Sumit Balhara about 1 year ago
    Tutorial.
    1. Step 1
      Start SolidEdge.
      Medium
    2. Step 2
      Circle tool and then select origin.
      Medium
    3. Step 3
      Make a circle of 20mm diameter on top plane by locking it clicking on the lock icon.
      Medium
    4. Step 4
      Select Extrude.
      Medium
    5. Step 5
      Select the circle and then right click.
      Medium
    6. Step 6
      Extrude by 100.
      Medium
    7. Step 7
      Polygon tool.
      Medium
    8. Step 8
      Top face and then select the center of the edge.
      Medium
    9. Step 9
      Distance be 16.5mm and angle 0.
      Medium
    10. Step 10
      Select the region of the polygon.
      Medium
    11. Step 11
      While pressing the control key on the keyboard select the region on the circular face also.
      Medium
    12. Step 12
      Extrude it by 12.5mm.
      Medium
    13. Step 13
      Select chamfer equal setbacks.
      Medium
    14. Step 14
      Lower edge and input value 5.
      Medium
    15. Step 15
      Front view (Control key + F).
      Medium
    16. Step 16
      Draw a line along Z-axis of 85mm with endpoint at origin.
      Medium
    17. Step 17
      Polygon by Center.
      Medium
    18. Step 18
      Click the intersection of these two edges.
      Medium
    19. Step 19
      Input Distance 1mm.
      Medium
    20. Step 20
      Select helix under cut features.
      Medium
    21. Step 21
      Select the line.
      Medium
    22. Step 22
      Select the polygon.
      Medium
    23. Step 23
      Click Tick mark button.
      Medium
    24. Step 24
      Input turns 22.5mm. Right click to accept it.
      Medium
    25. Step 25
      Now go to the end face of the thread. Select the face and then project the edges.
      Medium
    26. Step 26
      Extrude it by remove at ~10mm.
      Medium
    27. Step 27
      Our bolt is ready.
      Medium
Add your answer to: "Tutorial on Modeling Bolt in SolidEdge ST4?"
