Mechanical Design
Created by Ramazan ÇELİKBAŞ on 9 April, 2021
I am very new and some would say a "noob" in cad and I was wondering if anyone could help me make a rear sprocket for my moped. I can't find anything at stores that match what I need.
Here is some info i calculated:
Teeth: 22
Chain pitch: 15.875 mm (520 chain)
Roller diameter: 10.16 mm
Pitch diameter (PD): 111.55 mm
Pitch radius (PR): 55.775 mm
Outside diameter (OD): 121.08 mm
Root diameter (BD): 101.39 mm
Tooth depth (tip → root): 9.845 mm
Tooth thickness at pitch: 7.938 mm
Tooth tip width (chord at OD): 8.615 mm
Gap width at pitch: 7.978 mm
Central angle per tooth: 16.364°
Center hole diameter 37.8 mm
Bolt circle diameter (PCD): 46.5 mm
Number of bolts: 3
Bolt diameter: 8 mm
Bolt angular spacing: 120°
Addendum (tip extension from pitch circle): ~4.7625 mm
Dedendum (pitch to root): PD − BD = 10.16 mm
Tooth profile: ideally roller-envelope; flanks smooth, roots rounded
If you are so kind and decide to make it, please email the file to me at "sg.sohvagamíng@gmail.com" so i can cut it at school with a lasercutter. I think the laser took .dxf file.
