i need help converting this files into solid body , Can someone help me /
I'm triying with scan to 3D with solidworks, but is too complex the shape to process and it ends up collapsing the software, my Work station is powerful but still collapses the solidworks, if someone has other optionsm are welcome
thanks in advance
https://filebin.net/hi8hq3750kph55yj
Please recheck, are your files not corrupted? I tried to open in eDrawings on two machines: one has shown an empty space, another - corrupted screen.
thanks https://grabcad.com/kirill.romanenko-1 , and in fact the files are not corrupted. currently the file is functional in the final assembly of the design, but when making the drawing for the client, being mesh does not appear that single piece, so I was detailing it with the scan to 3d but without success.
or if you know any method or option so that a mesh file can be viewed in the general drawing, it would be helpful, I have currently searched for options and can not find it only to be able to visualize it in the drawing.
Hi,
What specific file extension you want it to convert to?.. i manage to convert it to x_t which contains 36 solid bodies and 14 surface bodies. Or you need only 1 single solid file? or can you use .stl file?
Hello https://grabcad.com/bunschi.sarmiento-1 and thanks, I'm interested in the format x_t
With al bodies and surfaces
Thanks a lot for the help
This is for you ...
Hope you find it useful
