Lucifermorning37 22 Oct, 2019 03:28 AM Hey guys. Please helpme this problemsI make a sheet metal to cover this side of part by using Base flange, (as show fig 1, 2) but problem is: i couldn't find a way to make a bend between them (as show fig 3). Please give me some ideas
Vinit Patel Oct 22, 2019 why don’t you try edge flange instead of base flange to cover if you want bend in that location. You can edit flange profile to match your side bend. Midhun Mathew Oct 22, 2019 You can use edge flange.Edit sketch by opening the edge flange option from design tree remove the constrains and adjust accordingly Rollin Shultz Oct 22, 2019 You can easily make bends by including a construction or sketch line where you wish to make the bend once the extrusion is complete. Lucifermorning37 Oct 23, 2019 thank you very much guys Lucifermorning37 Oct 23, 2019 thank you very much guys Srinivas Ashokkumar Oct 23, 2019 Give edge flange but make offset bend 0.1mm Lucifermorning37 Oct 23, 2019 Srinivas Ashokkumar Give edge flange but make offset bend 0.1mm thanks Log in or sign up to post a reply
