Design a skeleton driven iCopy that has an iLogic rule ??
Hi friends,
i am about making an iCopy file that has a skeleton to drive its components shape, and also this shapes should be controlled with an iLogic rule, this iLogic rule also suppresses some components based on some parameters and cinfigurations selectable by user. so i have now the main file that i have designed its skeleton, made its components also have programmed the neccesary iLogic code, so in this way every think works fine. but when i define it as iCopy and after that, when want to use this iCopy nothing works well, and the assembly loses its shape.
can anybody please help me solve this problem?
i will post other details or maybe files if necessary.
Regards
Reza
