Entry-level 3D scanner help
Hi everyone, our school needs to buy an entry-level 3D scanner. Before ordering, I would like to hear your suggestions on scanner selection and computer configuration. According to the survey feedback from teachers and students, ease of use is the most important factor, and powerful computers are not required.
In the FAQ at https://www.revopoint3d.com/pages/support-miraco, it says that MIRACO is a standalone scanner, so you don't need a computer, which I think is a good choice.
There is a question. MIRACO has two configurations, miraco and miraco pro. We mainly scan objects with a size of 200mm-800mm, and there are not too many restrictions on the scanning distance. I would like to hear your suggestions. Should I buy miraco pro, or do you think buying the standard version is enough? Another question is that because it involves further editing of the later model, a computer needs to be configured. For configuration, I also want to hear your suggestions.
In addition to MIRACO, if there are other good equipment recommendations, I am also willing to
Thank you in advance!
