facing problem in gear mate solidworks.
i have created a clock gear assembly , in which i completed all the standard mates now only task which is remaining is mating the gears. But I m facing problem when I use the gear mate. I applied gear mate between the gear(32).sldprt and gear(45).sldprt the gears do get meshed but gear(45).sldprt is passing through teeths of gear(32).sldprt i.e they are not colliding at the flanks.
kindly help me with the problem, thank you
Without checking the files, the error is - 99% - in the mates' direction...
Suppress ᗩᒪᒪ the gear mates, then unsuppress them one by one, checking each one by moving it so that it doesn't interfere with the other gears.
