How can I select in what direction to rotate an object ?
When I create an object - in example a circle or a rectangle - and subsequently want to rotate that object, how can I choose the axis I wish to rotate the object around ?
first you have to make some to group in group after you rotate this group and then do explode it's so easy
Hi Hardi
I have noticed all these
questions of yours are not
getting answer, I don't know maybe just to many questions LoL'ss
I think it would help you understand more about the software that you want your questions answer if you go and read and work away @ the tutorials that way you will pick up more and learn faster....
I hope you get what your looking for :)
