How can I use Programming in SOLID WORKS API programming?
I wants to design a part model in solid works by API programming,
but I wants to use VB.NET for proggraming,
How can I ineterface that,
Bit of a loaded question, you should start with some basic part before you have it building large parts.
You should check out the help file great resource
Make sure to include Sub Main
Dim swApp As SldWorks.SldWorks
swApp = New SldWorks.SldWorks()
swApp = Nothing
End Sub
You also need to make sure that you have references to solidworks libraries
Lastly this video may help with getting started.
Comments 3
