How can we convert solid modeling to sheet metal modeling in solidworks ?
Accepted answer
1 Other answer
To convert a solid model to a sheet metal model in SOLIDWORKS, follow these steps ->
i. Open your solid model in SOLIDWORKS.
ii. Click on "Insert" in the top menu, then select "Sheet Metal" > "Convert to Sheet Metal."
iii. In the Property Manager, set your desired parameters:
a. Base flange thickness
b. Bend radius
c. K-factor (material stretch factor)
iv. Select the face you want to use as the fixed face for your sheet metal part.
v. Click the green checkmark to apply the conversion.
vi. SOLIDWORKS will attempt to recognize bends and convert features automatically.
vii. You may need to manually add or adjust some sheet metal features like edge flanges, hem edges, or jogs.
viii. Use sheet metal-specific tools (e.g., "Flatten" or "Unfold") to work with your newly converted model.
xi. Verify that all bends are feasible and adjust if necessary.
x. Save your file as a new sheet metal part.
Note that not all solid models are suitable for direct conversion. Complex geometries or non-sheet metal-like features may require redesign or alternative approaches.
