How do i convert asm and prt files to stl files using fusion autodesk
Converting .ASM and .PRT Files to .STL in Autodesk Fusion 360
If you need to convert .ASM (Assembly) or .PRT (Part) files to .STL using Autodesk Fusion 360, follow these steps:
1. Import the .PRT or .ASM File into Fusion 360
For .PRT (Part) Files:
Open Fusion 360.
Click on the File menu → Open → Upload.
Drag and drop the .PRT file into the upload window.
Wait for Fusion 360 to process the file.
Once uploaded, open the file in Fusion 360.
For .ASM (Assembly) Files:
Ensure you have all referenced .PRT files in the same folder.
Upload the entire assembly:
Go to File → Upload and select the .ASM file and all related .PRT files.
Open the assembly in Fusion 360.
Fusion 360 may prompt you to resolve missing components—relink them if necessary.
2. Convert to Mesh (STL Format)
Once the .PRT or .ASM file is open, select the component or entire model.
Go to File → Export.
In the "Save as type" dropdown, select STL (*.stl).
Adjust Export Settings:
Refinement: Choose between Low, Medium, or High resolution.
Binary or ASCII format (Binary is smaller in size).
Unit selection (match the original file units).
Click "OK" or "Save".
Alternative Method: Using the Mesh Workspace
If the STL export option is disabled, try:
Convert to a Mesh:
Click Modify → Mesh → Convert to Mesh.
Then, Export as STL:
File → Export → Select .STL.
