How should i get correct results for solid-works simulation ?
Based on initial guess a mesh of solidworks simulation is set up for external limits around the object. i used different geometry as well because force is the function of geometry. still i didn't get accurate value as per theoretical data. how should i proceed to improve the results.
Accepted answer
In my experience, Solidworks is the least accurate simulation software primarily due to 2 reasons: no control over the type of mesh and continuously changing results due to mesh refinement.
I would suggest using a different software (I use ANSYS) to get more accurate results that match with theoretical ones
