How to add angle of projection symbol in Tittle block in Creo 3.0
I am using Creo 3.0. i have made tittle block using formats feature.
i did add the projection angle symbol in one block using the sketch feature that is available in the formats platform.
The problem i am facing is, every time i close the drawing and open the drawing, the projection angel symbol disappears.
Please help me with this issue.
Just by using the sketch, you could draw the angle of projection symbol in the format sheet which you are using. And whenever you start your drafting just click "empty with format --> browse --> select your format sheet" now you could always have the projection symbol as default. Save it and make "save backup", then it wont dis appear
