how to add commands to joints in DMU kinematics CATIA V5 ..? i tried but dono how to add...:(
please give some examples using point& curve joint in Kinematics
Hi, points & curve in DMU kinematics only work if the points is already coincident with the curve. It will not be able to enable the feature you are trying to do if the requirement is not met.
