How to add multiple views in AutoCAD?
You may want to check out the commands SolView and SolDraw to accomplish what you are looking for. Using Soldraw "after using SOLVIEW, visible and hidden lines representing the silhouette and edges of solids in the viewport are created and then projected to a plane perpendicular to the viewing direction" in model space. These commands are helpful and will also create three layers for each viewport created in paperspace, they are Dim, Hid and Vis appended to the end of each viewport name.
