How to create a simulation on bearings
i want to perform equivalent von mises stress in ansys on bearings by fixing outer rings and forces on inner rings,I have attached the solidworks file please help me out
Dear Venkata praneeth,
All you need to do is to import your cad model into ansys workbench
make sure your model does not have any conversion problem.
then open static structural
apply material properties in engineering data
then go to mesh and mesh your model with fine mesh with required element size
the apply your support as you mentioned like where you need supports or loads
assign load values
then choose your solution required like total deformation. directional deformation, or equivalent stress or von mises stress or fatigue life or safety factor.
then solve
you will have results.
regards,
Dhanasekar V
DHANASEKAR VINAYAGAMOORTHY
