How to create square spring in CATIA..? is it possible..? pls give some tips to create..:) Praveen kumar E 26 Mar, 2013 07:06 AM i tried but i didn't get the square spring... 1 Answer Gurudath Answered on 26 Mar, 2013 10:22 AM yes it is possible : ).plz check the attached cat.part available done with r16 version if you got the same or above release versions the file will open untitled.299.jpg square_spring.CATPart
