How to create table pattern and variable radius fillet in Creo ?
I started learning Creo and i'm stucked at many things, for example how to create table pattern, or variable radius fillet along a radial or complex path (not straight)...
http://www.youtube.com/playlist?list=PLBHPr-24ac73ScwMuQfgToQobHtsBZILe
see the playlist for advanced use of table pattern turner's cube and variable fillets
attach file
Answered with a tutorial: https://grabcad.com/tutorials/how-to-create-table-pattern-and-variable-radius-fillet-in-creo--2
You can create by using family table in creo.you can download tutorial video for family table in YouTube
To create table pattern go to extrude and create first object like box,cylinder, etc. now draw the pattern object and select the pattern object. Then go to pattern icon highlight the table pattern. First select length, ctrl+height, ctrl+diameter. go to edit give the required 1st member values, 2nd member values and so on. Then go to file and save. Again go to file and exit then select tick mark (green color). Then table pattern will be created
To create variable radius fillet, click the round tool and select the edge u wanna create variable fillet. At the bottom of ur reference tab(set selection tab), 1 and ur radius values is displayed in table. Now, right click that 1, click add radius, a point will be added for varying radius, enter radius and where u wanna change radius at edge. Likewise, u can create multiple points of varying radius...
