how to draw a wire ?
Depends on how you want the wire to look,if you were looking at the wire side on sketch that profile and use the as your path for a sweep then switch planes and sketch a circle profile for example for the body of the wire and then you can sweep that circle along the first sketch.Now you can get more detail for the wire this way but it's difficult to explain that in text format,if you upload a sketch for what your looking for it would really help.
