how to elongation a solid bady
how to elongation a object that start and end of this is have a many feature
in other words how to stretch a solid body in median
use flex (insert>flex) and use stretching. then move two plane where that want to stretching here
other way:
first split() body in two body, then use move feature(insert>feature>move or copy) and move one of body so we want to elongation, then go to insert>face>move and select surface of moved body to elongate the body , but in this stage we have two body that combine them, so go insert>feature>combine and select two body
