How to export Inventor models to Revit?
If you want to learn how to export Inventor models into Revit, then you should read the below tutorial...
Probably many of you are using Inventor models and also, maybe you want to use them in Revit, with available connectors.
In this tutorial you will find how to add BIM connectors to Inventor parts and export them as .adsk files in order to use them in Revit.
Answered with a tutorial: https://grabcad.com/tutorials/how-to-export-inventor-models-to-revit
