How to find torque required at input to raise a certain load at output using ansys/creo parametric in geared power transmission mechanism?
I have applied a load say 100N at output shaft and i want to know how much torque i need at input to lift that load? If some one knows how to do it in ansys or creo parametric. kindly contact me soon please. I've uploaded one iges format file and one creo parametric file.
As this seems to be the same problem here is a link to answer to another question.
https://grabcad.com/questions/how-can-i-simulate-90-degree-power-transmission-in-ansys-workbench
