How to learn advanced mould design using Cimatron?
i am working as tool room designer for two years and i want to learn advance in mould design using cimatron.
To be a good mould designer cimatron is just another tool. mould design knowledge is the key to being a good designer. Soak up a much information as you can from the others working around you.
Start with, "Designing Plastic Parts for Assembly" by Paul A. Tres.
Sample pdf: http://www.hanserpublications.com/SampleChapters/9781569906682_978156990-%206682%20Designing%20Plastic%20Parts%20for%20Assembly%208E%20SAMPLE%20PAGES.pdf
And, as Lawrie mentioned, spend time with mold designers. Even more time with the guys that service them and don't be afraid to get in there and lend a hand. You'll learn a lot in the process.
