How to learn press tool design, Design of Fixture and gages?
Accepted answer
Best way? Go work for a company that builds & designs tooling. Your engineering knowledge and more importantly, eagerness to learn should get you in the door. Then spend a lot of time with the folks that maintain the tooling. They can tell you what issues they see. If the company maintains a library of failure reports (FEA), those will also prove very helpful.
Having a good fundamental knowledge is important but most of what you need, you will gain on the job.
Good resources for die design: Die Design Handbook
https://www.abebooks.com/Design-Handbook-Society-Manufacturing-Engineers/30418600842/bd?cm_mmc=ggl-_-US_Shopp_Trade-_-used-_-naa&gclid=Cj0KCQiA89zvBRDoARIsAOIePbDF9DTtyDJsLHErgN4dK5Vscp-iRcexs4KWS9RPEW3wXFWRMW1hws8aAtVFEALw_wcB
