how to open NX models into solidworks and edit features
Im curious if theres a way to show the sketches, revolves that interact with with the NX model that i just placed into solidworks. ATM able to show sketches but they seem to be for show. you edit them they do nothing.
2 Answer
你可以将NX 3D mould 在NX软件中转换成x_t 格式文件,然后再用SW打开,打开以后使用SW特征编辑工具对相关的面或者实体使用移动面命令,或者扭曲命令等进行编辑。
you can not open NX file directly in to SolidWORKS, for that you need to save as NX file in to other file extension (.step, .iges, .perasold etc) then you can open this file in to SolidWorks.
