How to Reduce PDF Line Thickness
When we create PDFs of drawings from SolidWorks, the generated PDF line thickness appears too thick. However, the same drawing PDF generated from AutoCAD has good line thickness.
Please suggest how to adjust the settings so that the SolidWorks-generated PDF line thickness looks similar to the AutoCAD output.
I have tried every options below
1.Adjusted Line Thickness in SolidWorks
2.Modified Print Settings
3.Set Line Font Options
4.Checked View Settings
