Missing feed
how to stop relative motion between gear and shaft? as shaft rotate....the gear should rotate...so for that what are the constraints to be given between them?
By Ritin Patel on 27 Jun 04:50 0 answers 411 views 0 comments
mostly pin & slider constraint
final_1.asm.1, 64.8 KB
Download
Add your answer to: "how to stop relative motion between gear and shaft? as shaft rotate....the gear should rotate...so for that what are the constraints to be given between them?"
