how to use boolean operation in creo parametric 2.0
By Jins Joseph on 20 Nov 05:46 1 answer 1 comment
I have to add the shrinkage in creo model. also I have to cut that model from the die
1 answer
  • Raushan Kumar
    Raushan Kumar almost 2 years ago
    Use Cut Off feature in assembly . There is no Boolean operation command in Creo
Add your answer to: "how to use boolean operation in creo parametric 2.0"
