After creating or adding some parts in Main Assembly component how to call some more existing components which are having different dimensions but same components and save all the Assembly
We call it "paste special"
You can use 'Reuse pattern command / or if you could use 'Multi Instance Instantion' command to call existing parts or to create an instance.
Simply press' Save Management and save and propagate directory which will save all the parts under same folder
